YOUTUBE
backlight
YOUTUBE
Post by backlight »
Hi guys,
adding more workflows i'm trying to configure the YT Decoder....
I don't knwo what i'm doing wrong...
now is...
whatchfolder --> YT Decoder (config file + account information) --> X264 Encoder --> folder delivery
I "submit" the url (ex: https://youtu.be/nSxzsviTpSc) in the File filed... it gaves me the error (no audio/video) found!
Thank you for all your support and for this incredible GUI!
L
Re: YOUTUBE
Hi backlight,
Could you export and share the workflow?
backlight
Re: YOUTUBE
Post by backlight »
Thank you for your support Steinar...
here my WF
YOUTUBE_DONWLOAD.xml
(4.38 KiB) Downloaded 1048 times
jozxyqk80
Re: YOUTUBE
Post by jozxyqk80 »
Does the machine have an FFAStrans internet connection? It told me the same message if I had to have a proxy set up.
Ideally try downloading directly through the youtube-dl.exe file in the directory (e.g. C:\Program Files\FFAStrans\Processors\ffmpeg) using the bat file: "C:\Program Files\FFAStrans\Processors\ffmpeg\youtube-dl.exe" -f bestvideo+bestaudio filename"
or with proxy
"C:\Program Files\FFAStrans\Processors\ffmpeg\youtube-dl.exe" --proxy "http://IP_adress:port" -f bestvideo+bestaudio filename"
I have another problem and I will not create a new thread for it, it is also useful here:
video source https://www.youtube.com/watch?v=8uYG3dQt-RQ
if i testing in BAT file:
"C:\Program Files\FFAStrans\Processors\ffmpeg\youtube-dl.exe" --proxy "http://myproxy:port" --restrict-filenames -f bestvideo+bestaudio https://www_youtube_com/watch?v=8uYG3dQt-RQ
then output from youtube-dl:
PO_KRADE_I_KABELKY_VLA_EL_PRODAVA_KU_PO_ZEMI-8uYG3dQt-RQ.f135.mp4
PO_KRADE_I_KABELKY_VLA_EL_PRODAVA_KU_PO_ZEMI-8uYG3dQt-RQ.f140.m4a
OR
"C:\Program Files\FFAStrans\Processors\ffmpeg\youtube-dl.exe" --proxy "http://myproxy:port" --merge-output-format mp4 --ffmpeg-location "C:\Program Files\FFAStrans\Processors\ffmpeg\x64\ffmpeg.exe" --restrict-filenames -f bestvideo+bestaudio https://www_youtube_com/watch?v=8uYG3dQt-RQ
then output is: PO_KRADE_I_KABELKY_VLA_EL_PRODAVA_KU_PO_ZEMI-8uYG3dQt-RQ.mp4
if I set the url address to a shortcut (.url) and process it in FFAStrans -> Folder (url file) -> Youtube Decoder (in config file is):
# Restrict filenames to only ASCII characters, and avoid "&" and spaces in filenames
# Use this proxy
output from youtube-dl (Youtube decoder) is file "PO KRÁDEŽI KABELKY VLÁEL PRODAVAKU PO ZEMI.mp4" -> there is a problem with non-standard ASCII characters in the next process (e.g. ě š č ř ž ý á í é ú ů)
the settings in the configuration file do not work --restrict-filename, the output file name is fixed according to --get-title ???
Re: YOUTUBE
Hi jozxyqk80,
welchome to the forum!
It is always good to open an new thread about new problems as your problem might be completely different than the other ones.
I tried to reproduce your issue and initially i got an error message from the Youtube Processor like
 "token" parameter not in video info for unknown reason;
After updating the youtube-dl.exe (by just jusing youtube-dl.exe -U), i am not able to reproduce any problem, not the one from @backlight and not the one from @jozxyqk80
You can check the and play around with the generated youtube-dl command in a log file named *extract.txt in the work_root directory. Please check the option "keep jobs work folders on completion" in your workflow settings.
A log file name containing the full youtube-dl command on my system for example here:
C:\.ffastrans_work_root\20190614110502\20190614-122637-191-47DCE164D402\~20190614-122638-806-F61058FDEF52.extract.txt
jozxyqk80
Re: YOUTUBE
Post by jozxyqk80 »
thank you for answer
This is from the log:
=PROC=> 2019-06-17 11:05:38.532 on Folder@PC, PID: 14132 -> Ticketfile is "C:\Program Files\FFAStrans\Processors\.cache\tickets\x20190617-110538-161-BA6F7794C77D_20180707181815~loc~PC~20190617-110536-551-6EC54956B90E.ini"
=PROC=> 2019-06-17 11:05:38.535 on Folder@PC, PID: 14132 -> Getting top storage...
=PROC=> 2019-06-17 11:05:38.536 on Folder@PC, PID: 14132 -> Creating work dir: d:\.ffastrans_work_root\20180707181815\20190617-110536-551-6EC54956B90E
=PROC=> 2019-06-17 11:05:38.542 on Folder@PC, PID: 14132 -> Registering abort check...
=PROC=> 2019-06-17 11:05:38.544 on Folder@PC, PID: 14132 -> Executing ini: "mon_folder 20180713-152221-912-f835defc268c"
=PROC=> 2019-06-17 11:05:38.546 on Folder@PC, PID: 14132 -> Executing sys: "mon_folder 20180713-152221-912-f835defc268c"
=PROC=> 2019-06-17 11:05:38.550 on Folder@PC, PID: 14132 -> New file picked up by: "PC"
=PROC=> 2019-06-17 11:05:38.551 on Folder@PC, PID: 14132 -> ProcessorEnd_Routine(mon_folder 20180713-152221-912-f835defc268c)
=PROC=> 2019-06-17 11:05:38.553 on Folder@PC, PID: 14132 -> Ending process...
=PROC=> 2019-06-17 11:05:38.553 on Folder@PC, PID: 14132 -> =================================================================================================================================================================================
=PROC=> 2019-06-17 11:05:39.007 on YouTube@PC, PID: 14880 -> Ticketfile is "C:\Program Files\FFAStrans\Processors\.cache\tickets\x20190617-110538-680-A169B5CE5C4E_20180707181815~loc~POST-TRANSFER-1~20190617-110536-551-6EC54956B90E.ini"
=PROC=> 2019-06-17 11:05:39.007 on YouTube@PC, PID: 14880 -> Source is X:\Users\youtube43.url
=PROC=> 2019-06-17 11:05:39.009 on YouTube@PC, PID: 14880 -> Creating work dir: d:\.ffastrans_work_root\20180707181815\20190617-110536-551-6EC54956B90E
=PROC=> 2019-06-17 11:05:39.010 on YouTube@PC, PID: 14880 -> Registering abort check...
=PROC=> 2019-06-17 11:05:39.012 on YouTube@PC, PID: 14880 -> Executing ini: "dec_youtube 20190610-200913-310-f3dd8b8bc5b0"
=PROC=> 2019-06-17 11:05:39.013 on YouTube@PC, PID: 14880 -> Executing sys: "dec_youtube 20190610-200913-310-f3dd8b8bc5b0"
=PROC=> 2019-06-17 11:06:03.548 on YouTube@PC, PID: 14880 -> ProcessorEnd_Routine(dec_youtube 20190610-200913-310-f3dd8b8bc5b0)
=PROC=> 2019-06-17 11:06:03.550 on YouTube@PC, PID: 14880 -> Ending process...
=PROC=> 2019-06-17 11:06:03.550 on YouTube@PC, PID: 14880 -> =================================================================================================================================================================================
=PROC=> 2019-06-17 11:06:04.105 on Folder@PC, PID: 36 -> Ticketfile is "C:\Program Files\FFAStrans\Processors\.cache\tickets\x20190617-110603-736-D764526B992A_20180707181815~loc~PC~20190617-110536-551-6EC54956B90E.ini"
=PROC=> 2019-06-17 11:06:04.106 on Folder@PC, PID: 36 -> Source is d:\.ffastrans_work_root\20180707181815\20190617-110536-551-6EC54956B90E\yt\8uYG3dQt-RQ.mp4
=PROC=> 2019-06-17 11:06:04.108 on Folder@PC, PID: 36 -> Creating work dir: d:\.ffastrans_work_root\20180707181815\20190617-110536-551-6EC54956B90E
=PROC=> 2019-06-17 11:06:04.109 on Folder@PC, PID: 36 -> Registering abort check...
=PROC=> 2019-06-17 11:06:04.111 on Folder@PC, PID: 36 -> Executing ini: "dest_folder 20190610-192125-719-a3a9e3594dde"
=PROC=> 2019-06-17 11:06:04.113 on Folder@PC, PID: 36 -> Executing sys: "dest_folder 20190610-192125-719-a3a9e3594dde"
=PROC=> 2019-06-17 11:06:04.242 on Folder@PC, PID: 36 -> ProcessorEnd_Routine(dest_folder 20190610-192125-719-a3a9e3594dde)
=PROC=> 2019-06-17 11:06:04.243 on Folder@PC, PID: 36 -> Job completed without errors.
=PROC=> 2019-06-17 11:06:04.244 on Folder@PC, PID: 36 -> _EnumIfNewJob() with current queue:0
=PROC=> 2019-06-17 11:06:04.261 on Folder@PC, PID: 36 -> Ending process...
=PROC=> 2019-06-17 11:06:04.262 on Folder@PC, PID: 36 -> =================================================================================================================================================================================
Youtube-dl download file corectly -> 8uYG3dQt-RQ.mp4, but the file name is "PO KRÁDEŽI KABELKY VLÁEL PRODAVAKU PO ZEMI.mp4" even if I have in config.txt --restrict-filenames and it should be "PO_KRADE_I_KABELKY_VLA_EL_PRODAVA_KU_PO_ZEMI-8uYG3dQt-RQ.mp4"
The problem is with further processing with characters - ě š č ř ž ý á í é ú ů
Youtube-dl is updated at 14.6.2019 11:15
jozxyqk80
Re: YOUTUBE
Post by jozxyqk80 »
in ~20190617-112722-275-91A1480015C7.extract.txt
C:\Windows\system32\cmd.exe /U /C ""C:\Program Files\FFAStrans\Processors\FFmpeg\youtube-dl.exe"  --config-location "C:\Program Files\FFAStrans\Processors\ffmpeg\config.txt" -s -F -a "d:\.ffastrans_work_root\20180707181815\20190617-112719-872-5B6EF6431F6B\~20190617-112722-275-E5C462FEC4DE.url.txt" >> "d:\.ffastrans_work_root\20180707181815\20190617-112719-872-5B6EF6431F6B\~20190617-112722-275-91A1480015C7.extract.txt" 2>&1"
[youtube] 8uYG3dQt-RQ: Downloading webpage
[youtube] 8uYG3dQt-RQ: Downloading video info webpage
[youtube] 8uYG3dQt-RQ: Downloading MPD manifest
[info] Available formats for 8uYG3dQt-RQ:
format code  extension  resolution note
139          m4a        audio only DASH audio   52k , m4a_dash container, mp4a.40.5@ 48k (22050Hz)
251          webm       audio only DASH audio  130k , webm_dash container, opus @160k (48000Hz)
140          m4a        audio only DASH audio  134k , m4a_dash container, mp4a.40.2@128k (44100Hz)
278          webm       256x140    DASH video   95k , webm_dash container, vp9, 30fps, video only
160          mp4        256x140    DASH video  108k , mp4_dash container, avc1.4d400b, 30fps, video only
242          webm       426x234    DASH video  220k , webm_dash container, vp9, 30fps, video only
133          mp4        426x234    DASH video  242k , mp4_dash container, avc1.4d400c, 30fps, video only
243          webm       640x352    DASH video  405k , webm_dash container, vp9, 30fps, video only
134          mp4        640x352    DASH video  586k , mp4_dash container, avc1.4d401e, 30fps, video only
244          webm       854x470    DASH video  752k , webm_dash container, vp9, 30fps, video only
135          mp4        854x470    DASH video 1160k , mp4_dash container, avc1.4d401f, 30fps, video only
18           mp4        640x352    medium , avc1.42001E, mp4a.40.2@ 96k, 5.68MiB
43           webm       640x360    medium , vp8.0, vorbis@128k, 6.94MiB (best)
in ~20190617-112736-989-2AE0CA89566D.media.txt
C:\Windows\system32\cmd.exe /U /C ""C:\Program Files\FFAStrans\Processors\FFmpeg\youtube-dl.exe"  --config-location "C:\Program Files\FFAStrans\Processors\ffmpeg\config.txt" -e -a "d:\.ffastrans_work_root\20180707181815\20190617-112719-872-5B6EF6431F6B\~20190617-112722-275-E5C462FEC4DE.url.txt" >> "d:\.ffastrans_work_root\20180707181815\20190617-112719-872-5B6EF6431F6B\~20190617-112736-989-2AE0CA89566D.media.txt" 2>&1"
if I pause the download and change it in the media name to PO_KRADE_I_KABELKY_VLA_EL_PRODAVA_KU_PO_ZEMI-8uYG3dQt-RQ (it should create --restrict-filenames) it's alright
Re: YOUTUBE
So i had a deep look now into the internals of ffastrans. --restrict-filenames parameter from your config is applied to youtube-dl, but ffastrans is instructing it to download to a temporary filename. The temporary filename equals the youtube ID therefore it does not contain any special chars, this is why youtube-dl --restrict-filenames function is not doing what you expect it to do.
Internal steps for the youtube-dl processor:
-) parse formats using youtube-dl.exe
-) parse title using youtube-dl.exe, store in a variable (%s_display%)
-) download video using youtube-dl.exe, store to temporary location using temporary filename
So the actual filename is being parsed from the youtube title and applied later on by e.g. a deliver node.
Unfortunately the actual filename is only stored internally in a variable called %s_display%. You can use this variable to calculate your filename without special chars e.g. in a populate variables processor like that:
$alrep("%s_display%","_")
Actually i am more interested in whats your issue with the "special characters", you should not have any issues within ffastrans as far as i can see.
Anyway, @jozxyqk80 i am not very happy that we use this thread for it as the problem is a completely different one than the original was. Please open another thread if you need more infos about coping with special characters.
backlight
Re: YOUTUBE
Post by backlight »
Hi guys,
my problem is a little bit easier (I hope).
I can't understand how to setup my nodes and the conf file to use it into the workflow.
HELP
L
Re: YOUTUBE
Hi backlight,
I'm not sure I quite catch your problem. Is it creating and configuring the youtube conf. file or is generally how to use the youtube-decoder?
