Using a LUT (.cube) via workflow
I'm getting some Slog3 and C-Log videos and I'd like to apply a LUT to bring them to the standard linear curve with BT709.
I made a custom Avisynth Script like so:
# Variables:
# m_clip		= The last returned AviSynth media
# _ffas_video 	= <original video>
# _ffas_audio	= <original audio>
# _ffas_height	= <source height>
# _ffas_width	= <source width>
# _ffas_work_fdr	= Working folder for the workflow
LoadPlugin("C:\encoder\encoder\Processors\avs_plugins\LUTs\vscube.dll")
c=Converttoyv24(m_clip)
hbd=ConvertBits(c, bits=16)
plrgb=ConvertToPlanarRGB(hbd)
m_clip=Cube(plrgb, "C:\encoder\encoder\Processors\avs_plugins\LUTs\Slog3_Avisynth.cube")
Return m_clip
Then I go back to my usual workflow which includes Clipping Luma and Chroma to Limited TV Range, however I can't manage to make it work.
Since ffmpeg is actually able to use a LUT as well, I think it would be useful to create a Node called "LUT" that goes through ffmpeg and simply adds the "-vf lut3d=" command and then pipes the output to whatever.
You can find the Cube filter for avisynth here, instead: forum.doom9.org/showthread.php?t=175552
By making LUTs available, it would be useful for HLG / PQ as well.
Thank you in advance,
Frank.
Re: Using a LUT (.cube) via workflow
Hey Frank,
this sounds more like it fits to the feature request section as you already know how to apply the lut using ffmpeg. In tje meantime, this might help;
viewtopic.php?f=5&t=849#p3641
cheers, emcodem
For the records, I managed to get it to work by compiling vscube myself and it works perfectly fine with 16bit precision calculations.
As to the LUTs, I created them and I shared them here on Doom9: https://forum.doom9.org/showthread.php?p=1873351
- PQ to BT709 SDR
- HLG to BT709 SDR
- PQ to HDR HLG
- Slog3 to BT709 SDR
- Clog3 to BT709 SDR
- Clog3 to PQ
- Clog3 to HLG
- BT709 SDR to PQ
- BT709 SDR to HLG
Feel free to download and use them. ;)
Hello Franck,
Thanks a lot for this! It will be useful for sure.
I wonder if you work on Sony Slog 2? I must admit it will be useful for me :)
Thanks again.
momocampo wrote: Wed May 08, 2019 9:06 am Hello Franck,
Thanks again.
I don't use Slog2 anymore, but I do have some old contents shot using that curve.
I guess I can try to make a new LUT for it as well when I have time.
You need from Slog2 to BT709 SDR, right?
Very kind from you.
And yes, it's Slog 2 to rec 709.
Thanks ;)
momocampo wrote: Wed May 08, 2019 6:32 pm Hello,
Very kind from you.
Thanks ;)
It's almost ready.
https://forum.doom9.org/showthread.php? ... ost1874078
Next week I'm gonna make the final tweaks and I'm gonna upload it.
Great!! It's really kind to create this lut for me, I appreciate.
Thanks you very much.
LUT uploaded. Let me know if it works for you. ;)
Hello FranceBB,
Well I took it , thank you.
I must find how to test it with my slog2.
Can you help me to tell me where I can find avs plug in ? (vscube.dll into your avisynth script)
Thanks again.
