Possible error of bitrates?
rholm
Post by rholm »
I am running some conditional values, but according to the log the output looks incorrect
For the video I get an error: "%i_v_bitrate%<=600" is "497692<=600" - My bitrate is actually below 600 but it seems like being identified as 497692?
Some for audio: "%i_a_bitrate%<=128" is "62687<=128" - Same here, bitrate is below 128 but is noted as extremely high.
Am I doing something wrong or is it a bug?
THanks!
Re: Possible error of bitrates?
The bitrate values are presented in bit per second. Obviously you expect them to be presented in Kbit/s, so all you need to do is to divide by 1k, e.g.
%i_v_bitrate%/1000<=600
rholm
Post by rholm »
Ah, that makes sense, will try that!
Thanks!!!
