Getting videoId from Youtube GET request
flix
Post by flix »
Hi, first of of all thank you for this great software, so powerful. I'm not very experienced in parsing JSON files, thus I would need some help. The problem is getting the videoId from Youtube JSON reply. The goal is the get the videoid into a user variable, which is needed for a text file.
Here is the JSON:
 "kind": "youtube#playlistItemListResponse",
 "etag": "\"XpPGQXPnxQJhLgs6enD_n8JR4Qk/2gSn6UOOSh73oNWwLJlWeSZgNUc\"",
 "nextPageToken": "CAEQAA",
 "pageInfo": {
  "totalResults": 499,
  "resultsPerPage": 1
 "items": [
   "kind": "youtube#playlistItem",
   "etag": "\"XpPGQXPnxQJhLgs6enD_n8JR4Qk/6aBe6zCGCUhOnJxsjUmWU6CRWBQ\"",
   "id": "VVUxTVNqbHhQS2RYVURRWmJSU05zbDVRLlhwUy1vS3B2V0pR",
   "contentDetails": {
    "videoId": "XpS-oKpfgJQ",
    "videoPublishedAt": "2019-03-17T19:51:08.000Z"
flix
Re: Getting videoId from Youtube GET request
Post by flix »
Figured out the problem myself, here is the principle I used how to easily get all the information output in to file. I used curl GET on youtube API and then piped the json reply to jq. After that I output the information jq siphoned to a text file. Then using a user defined variable and $read in Populate variables to get the information into Ffastrans. Here one of the key things was to use the full path of curl and jq, otherwise it won't execute.
%comspec% /c "C:\Users\felix\Documents\curl\curl-7.64.0-win64-mingw\bin\curl.exe "https://www.googleapis.com/youtube/v3/playlistItems?part=contentDetails&playlistId=your_upload_playlist_id&maxResults=1&key=your_apikey" | C:\Users\felix\Documents\jq\jq.exe --raw-output .items[0].contentDetails.videoId > "D:\delivery\%s_original_name%_output.txt""
Hi flix,
sorry for the late answer, happy that you already found a nice workaround.
Instead of writing to a text file, you could just set the reply json to a user variable in the http node and in another node like e.g. populate variables, you could use something like that to parse your value of interest
$between("%s_rest_response%",'videoId": "','"')
explained:
$between is a function from ffastrans for string parsing, %s_rest_response% contains the rest value from the http node, 'videoId": "' (take care about the whitespace between the : and " here) is the start sequence and '"' the end sequence that you want to parse from your rest response :-)
flix
Post by flix »
emcodem wrote: Mon Mar 25, 2019 2:01 pm Hi flix,
explained:
Thank you for your reply. I tried understanding $between before going the workaround route. The mix of single and double quotes are quite intimidating for the uninitiated.
I was already familiar with XPath, so jq so was an easy route for me. It also was really easy to debug to get the correct response using online tools.
https://jqplay.org/
Is there an easy way to debug the output of the functions built-in to FFAstrans?
flix wrote: Tue Mar 26, 2019 2:19 pm Is there an easy way to debug the output of the functions built-in to FFAstrans?
Not sure if it is easy, but i always use the "write text file" node in order to investigate the current value of variables, like here:
viewtopic.php?f=5&t=849#p3550
