Hello Steinar,
I have a question about help text in workflow properties/Maintainnance :
"File list age
This option tells FFAStrans how many days it should "remember" what files it has processed. If a file has been registered longer than the number of days specified, AND the original file is gone, it will be deleted from cache. If the original file still exist you may check the "Remove from location" option in order to delete it."
Can you tell me if this feature exists? And if yes, where I can find it please?
Thank you very much.
Remove from location?
Re: Remove from location?
Hi Benjamin,
I'm sorry but this is an error in the docs and it will be corrected. All options for removing monitored files has been removed because of safety reasons. You must remove it manually, use the "Command executor" or remove it by some other means.
Hello Steinar,
Ok no problem, I suspected it
It was because I wondered if I miss a function.
CHeers.
CHeers.
