Hello All ,
first I want to say that this Software is amazing and life saver ,, We used it every day and never failed us .
I have a question regarding the logs , can i customize the logs ,, I mean i want to export the logs from Status monitor as simple as possible ,, for example : Filename1.mov (Success)| Filename2.mov(Failed)
does the software do something like that?!
Thanks guys for your help
Logs from FFAStrans
Re: Logs from FFAStrans
Hi, mgm21m, thank you for using FFAStrans and welcome to the forum!
Currently FFAStrans has no inbuilt mechanism to export logs to other formats. If you want the finished files log as it is, you can find it here:<your_ffastans_dir>\Processors\.cache\monitor\log.txt.
