XML Metadata Input / File Name
I was wondering if it would be possible to extract metadata from an xml and use it to add a suffix and prefix to the output file name?
Example:
Watchfolder > Hold (wait for MXF and XML with same file name) > Extract XML > Encode MXF to MP4 > Rename MP4 with Metadata > Move MP4 to Folder
The XML's in question is always the same file names as their MXF counterpart. The idea is to drop both into a watch folder at the same time and have the workflow encode the MXF to an MP4 and use metadata from the XML to rename the MP4.
I've attached an XML template we use. This is a standard DPP Broadcast sidecar XML. I've entered most fields with 'test'. It would be great to use the 'Advertiser' and 'Product' fields for the prefix and suffix.
Thanks.
Example:
Thanks.
Re: XML Metadata Input / File Name
Hello Graham,
I think you have to use the functions for your goal.
After your "hold", you have to populate variable (and several) and use the "between" function to "catch" what you want into the xml. Then, you will have the variable to use into prefix or suffix.
If you don't know how to do, please tell me and I will try for you
Here I come again,
It's my day of kindness, I give you a good workflow .
You just have to change the different path > Monitor folder and first populate variable path.
Set your H234 encoder too.
And delete or move your original files if you want.
benjamin
benjamin
- GRAHAM_WF.xml
- (12.1 KiB) Downloaded 1025 times
Thanks very much for this! working perfectly. I'm not great and scripting but I understand enough to apply what you've supplied to amend for future use.
Thanks again! I've posted my workflow with a few additional nodes below if it helps out anyone in the future.
Hey,
You're welcome !
I liked (and I always like) when someone can help me so if I can do the same thing I'm happy
cheers
You're welcome !
cheers
I'm looking at this workflow again and I wondered if it's possible to have something like the following:
We use forward slashes in our 'Identifier_Value' field for commercial clock numbers and hyphens for sponsorships.
So a commercial clock in Identifier_Value looks like XXX/XXXXXX/XXX and sponsorships XXX-XXXXX-XXX
We identify if the clock is a commercial or sponsorship in the 'Material_Type' field as 'Commercial' or 'Sponsorship'.
Is it possible for FFastrans to look at the Material_Type and know if it's a commercial but contains hyphens in the clock 'Identifier_Value' to move the xml and mxf file to a 'Reject' folder and vice-versa for sponsorships that contain forward slashes in the Material_Type field?
I hope that makes sense?
Hey graham,
while @momocampo is away, i'll try to take care of this case
unfortunately i did not find your uploaded example xml, so currently i can only give you a rough idea.
So, you say if your xml contains XXX/XXXXXX/XXX you want to go on normally but if it contains XXX-XXXXX-XXX then move the mxf and xml to a folder named rejected.
All you need for that is a "conditional" processor. On the left side, you can read the xml content and use regex to see if there is a XXX-XXXXX-XXX contained. On the right side, you just put in a "-".
Left side:
Condition:
Right side:
You insert this conditional processor right after your hold node and connect its output to the populate variables node. This way, only XXX/XXXXXX/XXX will go to the transcode node.
To go on and move other mxf and xml files into the rejected directory, we will need to use the "error" path of the conditional processor i mentioned first and a commandline processor.
Let me know if you can follow or you are totally lost. Please know that i do not want to just set up your workflow and send it to you but also i want you to learn and understand how everything works together.
Left side:
$regext($read("%s_original_path%\%s_original_name%.xml"),"...(-)......-...")Code: Select all
not equal to (<>), stringCode: Select all
-To go on and move other mxf and xml files into the rejected directory, we will need to use the "error" path of the conditional processor i mentioned first and a commandline processor.
Thanks for the help so far. I've attached an example of an XML that the workflow would read. TTP-TEST001-030.xml
The clock ID is in this field:
<id:Identifier_Value>TTP-TEST001-030</id:Identifier_Value>
I've inputted a dummy clock number. This clock number above is incorrect as it should be:
<id:Identifier_Value>TTP/TEST001/030</id:Identifier_Value>
__
With moving to an approved folder, could I not use a 'delivery node' instead of a command-line node?
What would the populate variables node contain? I do want to learn this part of FFastrans although I don't have much coding/scripting experience. Where is the best place to learn 'Regtext' ?
The 'TTP-TEST001-030.xml' is the xml to be read. Although the file name contains hyphens this is only because file names can't have / in them.
The <id:Identifier_Value> where the clock id is repeated is where it has to be TTP/TEST001/030.
__
- xml workflow.xml
- (11.76 KiB) Downloaded 1108 times
- TTP-TEST001-030.xml
- (2.43 KiB) Downloaded 991 times
My god i just realize we left you alone with this Graham! Big sorry for that, i don't understand how this could happen.
Ist this kind of the same nut you are trying to crack in the question you recently asked?
