How to use LoudnessAnalyzer to get EBU R128 compliant audio
JohnB1
Post by JohnB1 »
Hi Guys,
Hope all is well.
I am struggling with using LoudnessAnalyzer to get EBU R128 compliant audio.
I have used LoudnessAnalyzer, added variables, used these variables in the encoder setting to Conform -23 but for some reason, the output file is measured for -26.
Any solutions?
Regards,
John
Re: How to use LoudnessAnalyzer to get EBU R128 compliant audio
Hi John,
It's impossible say without knowing how you used the analyzer and what your output audio layout is. So you can either export and post your workflow or give us some more insight.
backlight
Post by backlight »
I tested mine using a tone... and results perfect!
