Conditional on populated variables
Mic
Post by Mic »
Hi everyone one,
Thanks for this great software!
We are currently building automated workflows at work and im trying to figure what im doing wrong... Im starting Jobs using a CSV file containing all the info I need to do the job. (source file path, branding, preload file, audio...) in a watchfolder.
My problem is when im using a variable populated via $read("%s_original_full%") from my CSV file in a conditional box it fail, if im using variable populated manually or any variable populated by FFASTrans... it work...
All my variables seem good in a generated text file...
Im receiving this kind or errors: Job ended wih errors on Conditional@mycomputer: 1st evaluation of "se=%s_prefix%" is "se=se"
Im using FFAStran 0.9.4
Re: Conditional on populated variables
Hi Mic, thank you for using FFAStrans and welcome to the forum! :-)
Can you please export your workflow and post it here toghether with a CSV sample file that's supposed to work with your workflow?
Mic
Post by Mic »
I found my problem, on my CSV, my variables were all on the end of each line and i was using the characters on the next line for my between fonction...
So a hidden character of change line must be hidden in my populated variable... my bad, i dont have any background in coding so it must be obvious for you... sorry for your time!
I will modify the way my csv are created to put something after the variable i use...
I will probably have more questions soon! :)
Thanks again for this great software!
