Hello all,
Well, I'm creating a new workflow for several video files to h264 encode. (Encodem) helps me to create a 2 pass encode and it works well.
But, it works well only if I process 1 file. If I try with 2 or more in the same time I have always errors. Honestly I don't know why, maybe because a variable is already use but not sure...
So, if someone can help me it will be good;)
I join my workflow (in progress), see only the 4 first nods, the others are for different bitrate.
I join also log files : one ok (only 1 file process) and another one with 2 files in same time.
Thanks !
Need help for custom ffmpeg encode 2 pass
- errors.txt
- (15.45 KiB) Downloaded 500 times
- ok.txt
- (15.04 KiB) Downloaded 486 times
- SMARTPHONE_2.xml
- (63.03 KiB) Downloaded 479 times
Re: Need help for custom ffmpeg encode 2 pass
Hey Benjamin,
I believe the filename for the file where the passinformation is stored is fixed by default. So it might cause troubles to run 2 ffmpeg processes that create their passfile in c:\tempo as you do currently.
Please try to add this to all ffmpeg commands (after the -pass 1 and -pass 2)
-passlogfile %s_job_id%%s_node_name%emcodem, wrapping since 2009 you got the rhyme?
Hey,
Coooollll. Thanks a lot emcodem, obviously it works
I just have to delete all this log files and it will be ok!
Thanks again H.
Thanks again H.
