Error code: 161 - The specified path is invalid
BGIYYZ
Post by BGIYYZ »
I'm having an issue with getting things to work the way I would like them to. I'm sure it's a simple setting I'm messing up, but I can't figure it out.
Okay, I use an antenna for my TV viewing and record shows using TVHeadend. I end up with files that are about 3.5Gb for 30 minutes and they live on a NAS with different folders for each show. For instance, \\PVR\show1, \\PVR\show2, etc.
Now, to save space, I would like to automatically encode the video files to take up less room. Once encoded, I have no need for the original file.
The NAS does not have the horsepower to do it's own encoding, so I want to use a separate Windows computer that is always on. I have mapped the PVR folder on the NAS as a drive on this Windows computer.
So, the workflow (so far) is very simple. First, I monitor the folders contained in Y: (which is a mapped drive to the NAS).
Then it gets encoded
Then it should get delivered, but here is probably where the problem happens
In the end, FFAStrans monitor says this:
In the deliveries node I have tried different %s_variables, but can't figure out the right one.
TL;DR
Basically, I want to
  • have FFAStrans monitor a remote folder for an unprocessed file that is not growing (ie: being recorded)
  • encode that file using a local computer
  • overwrite the original file in its original remote location getting rid of any temporary files on the encoding computer
Thanks for any help you guys can afford me!
Re: Error code: 161 - The specified path is invalid
Hi BGI, welcome to the forum!
i think you have to just put %s_original_path% as target Folder in the delivery Node. Definitely no "Y:" before as y: is already contained in s_original_path
In that kind of case, I prefer delivery in another folder and delete the original files after. Or use a suffix for delivery in same folder and delete original file.
cheers ,)
BGIYYZ
Post by BGIYYZ »
emcodem wrote: Thu Sep 05, 2019 2:21 pm Hi BGI, welcome to the forum!
Thank you emcodem - that was all it took!
