Monitor - Folder-node not working when duplicating workflow
maybe a little bug:
When I Duplicate a workflow from within the application, the Monitor-Folder-Node does not work.
Sometimes I can Re-activate it when I un-join it from the workflow, safe the workflow and re-join it to the workflow (and safe it again for sure...).
In other cases I have to re-write the Folder-Node to get the duplicated workflow running.
Maybe it´s worth considering to fix this behaviour in the next Version.
Thanks a lot,
regards,
tom
Re: Monitor - Folder-node not working when duplicating workflow
Hi tom,
Is this behaviour consistent? I have not been able to reproduce it.
