Hi All,
I am trying to see if there is a way to do loudness correction to match EBU r128 standard.
I know under analysis there is a loudness node.
The output format has to be MXF.
I used XDCAM encoder and selected match audio to -23, however when using software like Eff to determine if audio needs correcting then corrects it, it states that the file has failed loudness test and does not match EBU r128
- Abul
Loudness correction to EBU r128
Re: Loudness correction to EBU r128
Hi Abul,
How have you configured your loudness workflow? If you could describ, supply some screenshots or export and post workflow itself it's easier to help.
I have attached my workflow.
-Abul
-Abul
- Loudness.xml
- (10.5 KiB) Downloaded 753 times
Thanks abul. Your workflow looks ok.
I see you have chosen to measure stereo pairs in the "Loudness"-analyzer, which off course would be quite normal. But what does Eff measure, is it the two mono channels as one stereo pair or two independent channels? Do you have any output reports from Eff?
File Information
File Size: 5927029863 bytes
Audio Duration: 900.8 seconds
Sample Rate: 48000 Hz
Num Channels: 2
Bits Per Sample: 24
Analysis Time: 97.0 seconds
Analysis Speed: 9 x
Correction Time: 30.2 seconds
Correction Speed: 30 x
Channel Group Information
Number of Groups: 2
Channel Group Layout: Mono_Mono
Channel Group Name: MonoOne
Loudness Specification: EBU R128
Loudness Units: LUFS
Program Loudness Target: -23.0 LUFS
Program Loudness: -27.3 LUFS
Loudness Range: 8
PPM Scale: BBC
PPM Threshold: 8.00
Max PPM: 7.74
True Peak Threshold: -3.00 dBTP
Maximum True Peak: -2.14 dBTP
Attenuation required for file to meet target: 4.3
Channel Group Name: MonoTwo
Loudness Range: 8
PPM Scale: BBC
PPM Threshold: 8.00
Max PPM: 7.83
Maximum True Peak: -1.97 dBTP
1
The above is eff response
Num Channels: 2
Bits Per Sample: 24
Analysis Speed: 9 x
Number of Groups: 2
Loudness Range: 8
PPM Scale: BBC
PPM Threshold: 8.00
Max PPM: 7.74
Loudness Range: 8
PPM Scale: BBC
PPM Threshold: 8.00
Max PPM: 7.83
1
Ok, so you need to make sure that:
- The two channels are measured as a stereo pair, and not two mono which is what I read from the Eff output.
OR
- You need to change the analyzer to analyze mono with channel looping.
Please change either and report back.
OR
File Information
File Size: 273900125 bytes
Audio Duration: 39.9 seconds
Num Channels: 4
Bits Per Sample: 24
Analysis Time: 6.9 seconds
Analysis Speed: 6 x
Correction Time: 1.2 seconds
Correction Speed: 32 x
Number of Groups: 4
Channel Group Layout: Mono_Mono_Mono_Mono
Program Loudness: -26.0 LUFS
Loudness Range: 7
PPM Scale: BBC
PPM Threshold: 8.00
Max PPM: 6.32
Maximum True Peak: -7.71 dBTP
Attenuation required for file to meet target: 3.0
Loudness Range: 8
PPM Scale: BBC
PPM Threshold: 8.00
Max PPM: 6.34
Maximum True Peak: -7.73 dBTP
Channel Group Name: MonoThree
Program Loudness: -100.0 LUFS
1
Loudness Range: -100
PPM Scale: BBC
PPM Threshold: 8.00
Max PPM: 0.00
Maximum True Peak: -inf dBTP
Attenuation required for file to meet target: 0.0
Channel Group Name: MonoFour
PPM Scale: BBC
PPM Threshold: 8.00
Max PPM: 0.00
2
doing that caused it to get 4 channels rather than
***EDIT:
Ignore the above. i did 1 mono on loop and file passed
Selected the wrong option before :@
Num Channels: 4
Bits Per Sample: 24
Analysis Speed: 6 x
Number of Groups: 4
Loudness Range: 7
PPM Scale: BBC
PPM Threshold: 8.00
Max PPM: 6.32
Loudness Range: 8
PPM Scale: BBC
PPM Threshold: 8.00
Max PPM: 6.34
1
PPM Scale: BBC
PPM Threshold: 8.00
Max PPM: 0.00
PPM Scale: BBC
PPM Threshold: 8.00
Max PPM: 0.00
2
***EDIT:
Ok, I'm not sure what's going on with Eff, don't know the program....
Could you import the attached workflow and manually submit some files to the first loudness node, and then see what the outcome in the status monitor is? On each file you should see two different results in the form: "[-dB, -dB]", where one is the original -dB and the other is the new -23 (+/- 0.5).
- Loudness-2 test.xml
- (8.82 KiB) Downloaded 766 times
It working now, I get the report its passed eFF.
Just a quick question, if I want to do the loudness on an MXF file, is there a way to pass it through XDCAM without it encoding again but adding the volume control. for example the options none, transwrap or wrap when possible?
I want to be able to apply the loudness filter on mxf files as well, however, I don't want to reencode as they are over 6GB and takes time to encode
