Normalize Issue
abul
Normalize Issue
Post by abul »
There is an issue I wanted to know if there's something to avoid it with the normalize node.
The Issue is this
Folder -> Normalize (-23 dB) -> Output
The first instance, the outcome is "job ended with error on Normalize@Abul: No AVS source! Please insert "A/V Media" decoder"
Re: Normalize Issue
Hi Abul,
did you try what the error message tells you: insert the A/V Media decodr?
So your workflow looks like this :
Folder -> A/V Media Decode->Normalize (-23 dB) -> Encode -> Deliver
