Hi All,
this is happening for a while now and I'm not sure if it's fixed.
When i delete a workflow, then select another workflow to delete, it doesn't pop up with the message, do you want to delete it.
Also, the one i deleted sometimes does not go away from the workflow list even though it's not clickable.
Another issue i noticed is that if i double click on a workflow, after closing a node, it minimises FFastrans.
- Abul
Cannot delete 2nd workflow and more
Re: Cannot delete 2nd workflow and more
Hi abul,
Several GUI related issues has been fixed in the upcoming version 1.0.0 of FFAStrans and so this issue will not be fixed in the current version.
