need help with command executor and ssh
Drizzik
Post by Drizzik »
Hi all,
I'm a new user of FFAStrans (which is really good!!!) and I was wondering if it's possible to use "Command Executor" or anything else to connect and launch a custom ffmpeg command using SSH.
I tried using putty or plink but it seems I am not skilled enough.
The VM I want to connect uses linux but it shouldn't be a problem. All I need is :
- connect using ssh
- move to the folder I want
- launch ffmpeg custom command
I success to connect to the VM, but once I'm in, it doesn't want to do anything more.
(How should I write my 3 commands ? with "&&", with different "command editor" , ...?)
Thank you in advance.
PS: please excuse my awful english.
Re: need help with command executor and ssh
hey Drizzik,
The Command Executor is what you want. All you need to do is to make it work in a command prompt, without using ffastrans and when you are done, then you can copy/paste your command into the commandline processor. 2 commands in one line would be connected by a single "&".
This is what i would do if i was you:
-) Start without using ffastrans at all. Just use cmd promt and batch file alone.
-) I believe the best would be if you write what you want into a batch file
-) as soon as you have a working batch file that processes one file, you can post your batch here and i can show you how you can use variables and the "generate text" processor to generate this batch dynamically and later on execute the dynamic batch using the commandline processor...
