Table of Contents
Audio Extraction
Purpose
Description.
Example usage
Original Manual
Format
Bit depth
Bitrate (kb/s)
Sample rate
Discrete tracks
Source channels as tracks
Same as source
Total channels
Set custom mapping
Wrapper
Use RF654
Conform volume
