Extracts audio from media to one or more output files (stream copy possible).
PCM | FLAC | ALAC | MPEG1 Layer 1 | MPEG1 Layer 3 | Advanced Audio Codec | Windows Media Audio | OGG Vorbis | |
Wrapper | WAV-AIFF-AIF-PCM | FLAC | MOV-M4A | MP2-WAV | MP3-WAV | AAC-M4A | WMA-WAV | OGG-WAV |
Sample Rate(KHz) | 8000-11025 22050-24000 44100-48000 96000-192000 | 8000-11025 22050-24000 44100-48000 96000-192000 | 8000-11025 22050-24000 44100-48000 96000-192000 | 22050-24000 44100-48000 | 8000-11025 22050-24000 44100-48000 | 8000-11025 22050-24000 44100-48000 96000 | 8000-11025 22050-24000 44100-48000 | 8000-11025 22050-24000 44100-48000 |
Bit Depth | 8-16-24-32 | 16-24 | 16 | 16 | 16 | 16 | 16 | 16 |
Format
Sets the audio format and codec. "Uncompressed" and "Lossless" gives no quality loss. The latter is lossless compressed. depth
Bit depth
Bitrate (kb/s)
Sample rate
Discrete tracks
Source channels as tracks
Same as source
Total channels
Set custom mapping
Wrapper
Don't use naming convention on files < 2
Conform volume
