processors:encoder_audio_extraction
Audio Extraction
Purpose
Extracts audio from media to one or more output files.
Original Manual
Format
Bit depth
Bitrate (kb/s)
Sample rate
Discrete tracks
Source channels as tracks
Same as source
Total channels
Set custom mapping
Wrapper
Use RF654
Conform volume
2019/12/09 16:19
processors/encoder_audio_extraction.1581376887.txt.gz · Last modified: (external edit)
