Table of Contents
Audio Extraction
Purpose
Extracts audio from media to one or more output files.
| PCM | FLAC | ALAC | MPEG1 Layer 1 | MPEG1 Layer 3 | Advanced Audio Codec | Windows Media Audio | OGG Vorbis | |
| Wrapper | WAV-AIFF-AIF-PCM | FLAC | MOV-M4A | MP2-WAV | MP3-WAV | AAC-M4A | WMA-WAV | OGG-WAV |
| Sample Rate(kHtz) | 8000-11025 -22050-24000 44100-48000 96000-192000 | 8000-11025 22050-24000 44100-48000 96000-192000 | 8000-11025 22050-24000 44100-48000 96000-192000 | 22050-24000 44100-48000 | 8000-11025 22050-24000 44100-48000 | 8000-11025 22050-24000 44100-48000 96000 | 8000-11025 22050-24000 44100-48000 | 8000-11025 22050-24000 44100-48000 |
| Bit Depth | 8-16-24-32 | 16-24 | 16 | 16 | 16 | 16 | 16 | 16 |
Original Manual
Format
Bit depth
Bitrate (kb/s)
Sample rate
Discrete tracks
Source channels as tracks
Same as source
Total channels
Set custom mapping
Wrapper
Use RF654
Conform volume
