processors:encoder_audio_extraction
Audio Extraction
Purpose
Extracts audio from media to one or more output files (stream copy possible).
PCM FLAC ALAC MPEG1 Layer 1 MPEG1 Layer 3 Advanced Audio Codec Windows Media Audio OGG Vorbis
WrapperWAV-AIFF-AIF-PCMFLACMOV-M4AMP2-WAVMP3-WAVAAC-M4AWMA-WAVOGG-WAV
Sample Rate(kHtz)8000-11025
22050-24000
44100-48000
96000-192000
8000-11025
22050-24000
44100-48000
96000-192000
8000-11025
22050-24000
44100-48000
96000-192000
22050-24000
44100-48000
8000-11025
22050-24000
44100-48000
8000-11025
22050-24000
44100-48000
96000
8000-11025
22050-24000
44100-48000
8000-11025
22050-24000
44100-48000
Bit Depth8-16-24-3216-24161616161616
Original Manual
Format
Bit depth
Bitrate (kb/s)
Sample rate
Discrete tracks
Source channels as tracks
Same as source
Total channels
Set custom mapping
Wrapper
Use RF654
Conform volume
2019/12/09 16:19
processors/encoder_audio_extraction.1581505807.txt.gz · Last modified: (external edit)
