processors:monitor_sequence
Image Sequence Monitor
Purpose
…DESCRIPTION…
Example usage
Original Manual
This monitor will check folders for image sequence. By default it will search for matching file patters that include numbers.
Set folder that will be monitored. May be local or UNC. Supports variables and drag'n drop.
Accept/Deny files
Deny folders
Create folder
Recurse
Forget missing files
Accept digits
Sets the number patter to search. E.g. 000 will search for files pattern with three digits.
Interlaced input
Sets the scan type of the still frames.
Minimum number of frames
Specifies the minimum number of frames in continuously order before accepting the input pattern.
Framerate
Sets the frame rate of which the sequence should be processed.
Rebuild history
Clear history
2020/02/10 15:52
processors/monitor_sequence.1581278640.txt.gz · Last modified: 2020/11/16 19:08 (external edit)
