processors:monitor_folder
Folder Monitor
Purpose
This processor is used at the start of a workflow to watch for new files in a Local or UNC Path.
Limits
The settings “Forget missing” and/or “Growing Check continuous” raises the RAM and CPU usage of this processor in case your Watchfolders contain many (e.g. thousands) “already processed” files.
To work around the extra time/CPU load for “Forget missing” in case of huge watchfolders, use a commandline processor with this content: %comspec% /c “if exist ”%s_cache_record%“ del /f /q ”%s_cache_record%“”
Without any of those 2 settings, the Processor was tested for
  • 500.000 Files in a complex subfolder structure
  • it took about 16 minutes to pick up new files
NOTE : All variables can't be used inside this processor, you can only use:
  1. Static Variable
  2. Time Variable
  3. Windows Variable.
Potentially the processor can do more than the tested amount of Files but consider that it will take a long time to pick up new files.
Original Manual
This node is for monitoring local or UNC paths. Be aware that the "Recurse" and "Forget missing files" options will cause the monitor, run in a separate process, to use more CPU. This is most notable when monitoring thousands of files.
Folder
Set folder that will be monitored. Supports drag'n drop.
Accept/Deny files
Deny folders
Deny attributes
This enables you to skip files marked with any of the RASH attributes.
Create folder
Recurse
Localize file
If set, FFAStrans will make a local copy of the accepted files. These are just preliminary files and will be deleted once the job is done.
Check for growing files
The speed of the cycle is defined by the sleep timer setting in the workflow properties.
once: This option will make FFAStrans wait to see if incoming files are still growing. If FFAStrans do not detect any growth since last cycle, the file is considered finished and ready for processing.
continuously: This option will make FFAStrans execute new job every time the file(s) have changed file size. This comes in handy when looking for constantly updated files that need to be processed for each update.
Skip source verification
When enabled FFAStrans will skip trying to open the file for reading in order to verify if it's ready or not.
Limit file size
Rebuild history
Clear history
2019/12/09 16:19
processors/monitor_folder.txt · Last modified: 2021/10/31 16:09 by benjamin
