processors:filters_color_conversion
Color Conversion Filter
Purpose
(Needs A/V Media decoder before this node). Converts between color spaces.
Color Spaces : RGB24 - RGB32 - YUV 420 - YUV 411 - YUV 422 - YUV 444
Color Matrix : Rec 601 - PC 601 - Rec 709 - PC 709
Level Conversion : None - 0-255→16-235 - 16-235→0-255 - Custom
Original Manual
Color space
Converts video to desired colorspace.
Color matrix
Defines the color matrix you want to convert the video into.
Level conversion
Here you can set the desired output luminance level of the video. Ordinary 8 bit video for TV tend to use 16-235 while computer video use full scale 0-255.
2019/12/09 16:19
processors/filters_color_conversion.txt · Last modified: 2021/10/31 17:32 by benjamin
