system:processes
Process overview
General Information
  • What is an a3x file
  • Farm Mode
Note that there is no difference between running on a standalone host or in a farm. The processes are the same on each and every member of the farm. All nodes look for new Job tickets in the same folders and compete against each other getting a job assigned (depending on CPU settings, “farm host exceptions” etc.)
ffastrans.exe
  • User interface for Host and Farm settings as well as worfklow building and management
  • when rest_service is NOT installed, it fulfills the job of rest_service
rest_service.exe
  • keep exe_manager alive
  • provide http API service
In this picture, we see that rest_service.exe took care about starting exe_manager.
exe_manager.exe
  • Pending: New jobs from monitors always starts here.
  • Queue: New (from API or manually submitted) goes in here. This is also the place for existing that wait for next processors execution. Queue has higher priority than pending and will always be executed before any pending tickets.
  • Running: These tickets are the current running tickets and should correspond to the number of processors started by exe_manager.
  • Check if there are new job tickets in queue or pending and if the settings allow to process the new ticket, move to running
  • Start def_runner.a3x process which takes care of monitoring (in case there are any active workflows with monitor processors)
  • Clean the history logs for all jobs.
  • Auto update youtube-dl
  • Restart orphaned jobs by comparing running tickets with active processes, each host of the farm only takes care about tickets it took for processing
def_runner.a3x
processors.a3x
Priority flow chart and example
Since the 1.1.0.0 FFAStrans release, all the jobs are processed regarding to their priority :
FFAStrans Workflow properties\Priority → 0(Very Low)-1(Low)-2(Normal)-3(High)-4(Very High)
Each time a new higher priority branch (or job) is being put into queue, it will start before all lower priority queuedjobs * Once a branch/job has been started, the priority does not matter anymore *
Example for 4 max active jobs on 1 host, 2 hosts with 2 max active jobs or 4 hosts with 1 max active job:
Job Ticket Management
  1. Various job starting methods create tickets (.json file) in either pending or queued folder
  2. Queued or pending tickets are being read by exe_manager
  3. exe_manager spawns a processors.a3x process for each ticket
  4. processors.a3x reads ticket, decides if the current host and CPU allows to execute the ticket and in case it executes the processor from the current ticket
  5. when the processor finished, processors.a3x parses from the workflow which processors are next to be executed and places the corresponding tickets into queued folder, the process starts over at 3
The Status directory
TOOD: processors.a3x checks for status pause or abort of a job split, exe_manager for “.start~%workflow_id%” to see if def_runner needs to be started
system/processes.txt · Last modified: 2024/01/28 10:26 by benjamin
