Line 53338 Subscript used on non-accessible Variable
dinesh24
Re: Line 53338 Subscript used on non-accessible Variable
Post by dinesh24 »
Could you please help me on issue...
-Dinesh
Can you please go to "Help"->"About FFAStrans" and give med the FFAStrans.exe file version?
dinesh24
Post by dinesh24 »
My FFAStranz Version is 0.9.2...
-Dinesh
Yes I understand that but I need to know the file version of the FFAStrans.exe file, not the main version, which is just 0.9.2. So it should read 0.9.2.8 or something like that.
Thanks.
dinesh24
Post by dinesh24 »
Thanks for update...
It is 0.9.2.9..
Please find attached screen shot..
-Dinesh
The error is related to reading the workflow files which is in a .ini form, and it's trying to read out all the sections in the current workflow but is unable to. This tells me that there is a problem reading from the location of the workflows or you have corrupt workflows, unless it's some other bug. My guess is that it's the SAN that's causing the problem for FFAStrans. It's probably not the SANs fault and I have seen some issues earlier with the routine for reading ini files under some conditions. Your SAN setup might be one of those conditions.
Anyway, I will take a look at how to deal with this problem and get back to you. Sorry for the inconvienience.
Could you zip your workflow-folder as it is and send it to me? Just to rule out corrupt workflows.
dinesh24
Post by dinesh24 »
Thank you for support...
Please find attached workflow folder..
-Dinesh
Workflows.zip
(11.21 KiB) Downloaded 842 times
