Concatenate
Silicon
Re: Concatenate
Post by Silicon »
Hi emcodem
I'm testing the same trick i.e. modify s_source variable using the function $replace('%s_source%','\\?\UNC','[') - I have added it into the first Populate variables node of your wf. But foolowing node still works with the original s_source with \\?\UNC.
I'm missing something very stupid, but I don't know what it is :x
emcodem_webuisubmit_concat_correctUNC.json
(7.36 KiB) Downloaded 632 times
modify s_source var.PNG (22.95 KiB) Viewed 10604 times
BR,
Silicon
Silicon
Re: Concatenate
Post by Silicon »
Silicon wrote: Sun Nov 13, 2022 12:27 pm I have added it into the first Populate variables node of your wf. But foolowing node still works with the original s_source with \\?\UNC.
OK, I have found a workarround, but still ... grrr :evil:
BR,
Silicon
Silicon
Re: Concatenate
Post by Silicon »
Silicon wrote: Sun Nov 13, 2022 2:05 pm OK, I have found a workarround, but still ... grrr :evil:
Just to explain.... I'm mad about me not being able to make it work as required :?
BR,
Silicon
Re: Concatenate
Hey @Silicon,
check out my updated workflow, it is using a new variable instead of s_source.
When you do
%s_source% = $replace('%s_source%','\\?\UNC','[')
Then ffastrans will immediately redo the changes internally.
Instead you need to drop the usage of s_source throughout the whole workflow and replace it by some user variable e.g.
%s_sanitized_source% = $replace('%s_source%','\\?\UNC','[')
From this moment, s_sanitized_source contains the interesting data and s_source should not be used anymore.
I wrote this in the post where i suggest the replace:
in another variable than s_source because ffastrans would immediately redo the change.
Sometimes the stuff that i write contains vital information without highlighting it, sorry for that.
Silicon
Re: Concatenate
Post by Silicon »
Hi @ecmodem
emcodem wrote: Mon Nov 14, 2022 8:06 am When you do
That's exactly the workarround I've applied - use a new variable instead of s_source. So in fact it is not a workarroud but a proper way ... OK :roll:
I've missed this cruccial info that one have to use another variable than s_source because ffastrans would immediately redo the change :(
Thanks a lot indeed
BR,
Silicon
Re: Concatenate
Well all of it is a workaround until the issue is fixed in a new ffastrans version :D
Basically i could also hide the error by not using s_source for array job submission from webinterface but the only alternative is to use a user_variable but it would have to be "created" by the user before and i would not know an easy way how to tell webinterface in which userinput the filelist goes...
Silicon
Re: Concatenate
Post by Silicon »
It's fine emcodem, II have reached my point.
:idea:
You should probably consider changing the text on help page https://ffastrans.com/wiki/doku.php?id= ... _variables saying %s_source% represent the input file for any processor. It can be altered using the “Populate variables”-node ... in fact it can't be altered ;)
Anyway thanks again for this new feature!
BR,
Silicon
Re: Concatenate
@Silicon s_source can be altered to your desire at any point in the workflow. In this case, we just found out in ffastrans Version <= 1.3:
If the value is longer than 256 characters and these chars contain \\ or X:, ffastrans will replace the first character to \\?\UNC
That should be the exact description of what happens internally to s_source in our case here.
Looking forward to hear if your concat usecase finally worked :D I believe we need to work on the sorting because it should be sorted exactly as the user sorted it on webui but the files find will sort the transcoded files by name actually...
Silicon
Re: Concatenate
Post by Silicon »
@ecmodem. Thank you explanation.
As for your question: for my usecase the sorting of source files based on filnames is OK, because I need to merge individal files originated from XDCAM disc or SxS card, where the naming convention is "sequential". But you are right that another usecase could require user-defined sorting.
Another topic to think about: should the user be advised then his list of files contains mixed resolution (SD and HD) or even mixed framerates?
BTW You've mentioned Find Files plugin: When I set Include filter to *.mxf,*.mp4 the main branch of workflow fails, becasue Find Files is not able to create Concat file properly.
So the question follows: how to modify the workflow properly to proccess just MXF and MP4 files (because BFU will certianly submit also the sidecar XML files :P)
BR,
Silicon
Re: Concatenate
@Silicon
You are right, the include filter was broken when used with multiple include patterns, i fixed that now and uploaded a new version (also added a size filter)
https://ffastrans.com/wiki/doku.php?id= ... processors
But in the example workflow "emcodem_webuisubmit_concat_different_formats", it does actually not really make sense to set the files find to multiple extensions. It only lists the files that the lower branch transcoded so there is no way you need to include multiple extensions. Not to mention that multiple extensions would imply multiple different formats which would automatically lead to fubar output file at the concat.
About the topic "warning the user about mixed framerates and such", i suspect usually users are not interested in format specific warnings. Also, the "different_formats" workflow examples that i posted here do not care about format specifics, they just transcode everything. If you want to change that, you could for example use the "transwrap when possible" option in the xdcam encoder or add a decision and a second branch in the "per file" branch.
You know what i mean?
I'm interested in your xdcam/sxs workflow, but let's talk about that in PM's so we don't spam this concat thread with it :D
