1. In "Populate Variable Node", Beginning and Ending of Double Quote (") are missed after conversion.
2. In "Generate Text Node", Beginning and Ending of Double Quote (") are missed after conversion.
3. Encoders - Audio Extraction with wrong bit rate for discrete channels. When 24 bit is set, only apply to first track. The rest are all 16 bit. In contrast, if single track multi-channel setting is used, all channels are 24 bit correctly. Further, with auto zero padding enabled, Track 10 is with suffix as 010 instead 10.
Some issues encountered while upgrade from 0.9.4 to 1.0 (with patch 1.0.0.2)
Re: Some issues encountered while upgrade from 0.9.4 to 1.0 (with patch 1.0.0.2)
Hi bilibalabi, thank you for using FFAStrans, reporting bugs and welcome to the forum!
The audio nodes issues has all been addressed in the upcoming 1.0.0.3 update.
I will take a look at the other "quote" issues.
Hi again,
I have found the cause of the quote issue and it will be fixed in the next bugfix update.
