Command execute move original file not found
llittleton
Post by llittleton »
ffastrans version 1.1.0.43.
I have a workflow that has this command execute node:
%comspec% /c "move /y "%original_full%" "Q:\Broadcast_Services\EVS\Export\EVS_Export\MXF\UHD\Processed""
The output folder exists. If I add a text node and add "%original_full%" it shows the full path to the original file.
The error is:
Process exited with error code: 1 (The system cannot find the file specified.)
Please advise,
Lawrence
Re: Command execute move original file not found
Hello again :-)
do you run ffastrans as a service? ...if yes you might want to change "Q:" to the full unc path, e.g. "\\server\share" and also make sure the windows service has the correct credentials to run as...
If no, can you please create c:\temp\test.txt and try on commandline like this:
move /y "c:\temp\test.txt" "Q:\Broadcast_Services\EVS\Export\EVS_Export\MXF\UHD\Processed"
llittleton
20210218-1816-4338-902b-f04b9c0f06dc.json
(20.16 KiB) Downloaded 573 times
I do not run ffastrans as a service.
test.txt file moves successfully:
C:\Users\llittleton>move /y "C:\Users\llittleton\Desktop\test.txt" "Q:\Broadcast_Services\EVS\Export\EVS_Export\MXF\UHD\Processed"
1 file(s) moved.
Original file moves successfully:
C:\Users\llittleton>move /y "Q:\Broadcast_Services\EVS\Export\EVS_Export\MXF\UHD\Cam01_Chipchart_27-JAN-2021.mxf" "Q:\Broadcast_Services\EVS\Export\EVS_Export\MXF\UHD\Processed"
1 file(s) moved.
Switched out Q:\ with \\10.238.104.91\QMedia\ in workflow and still have the system cannot find the file specified.
Weird.
Lawrence
Howdy.
well thats really weird... anyway, we must go on find out the "EXACT" command that was executed by ffastrans. It should be included in the logs.
One easy solution to see the logs is to install the webinterface and check out the job details view. Otherwise, could you zip and send me the full_log.json (FFAStrans\Processors\db\cache\jobs\....) and work dir contents of a failed job please?
Sure you have to configure your workflows to "Keep job folders on completion" in the "Maintenance" tab and zip and upload the stuff - but of course do not include any huge media files.
Upload here: https://ffastrans.com/share -please create some new folder in the temp folder.
Sorry for
llittleton
I ran it again and explored using the web interface, so awesome!
Here is detail from web interface:
command C:\WINDOWS\system32\cmd.exe /c "move /y "%original_full%" "\\10.238.104.91\QMedia\Broadcast_Services\EVS\Export\EVS_Export\MXF\UHD\Processed""
code 1
msg
last_std
looks like it is using the literal %original_full% instead of the actual path.
SOLUTION: I changed it to %s_original_full% and works now!
Lawrence
Damned i should have noticed in your first post, sorry :D
