Correct Video Layer Setting for Transparency Channel (AVI)
authorleon
Post by authorleon »
Would somebody please tell me what are the correct settings I should use in Adobe Premier to export an AVI with transparency?
I tried quite a few settings over the last hour and had no success.
Re: Correct Video Layer Setting for Transparency Channel (AVI)
I think Microsoft RLE or Uncompressed 422 should be ok but check your file size cause it's gonna be huge :)
authorleon
Hi, I gave the following a go.
None of them worked.
I have a chroma video / used ultra key.
Am I missing something?
momocampo wrote: Sun Jan 08, 2023 11:17 am Hi,
RE: Correct Video Layer Setting for Transparency Channel (AVI)
Well obviously premiere does not offer any general purpose codec with alpha channel in avi container, you'd need to look out for something with a 4th component like 4:4:4:4 or yuva or rgba
Question is why you are bound using avi container, it is probably the oldest, most limited one you can go for :D
Why not use mov instead or such? Which target software does support alpha in avi anyways?
One alternative way for working with formats that don't support alpha is to export 2 versions, key and fill into separate files.
Some example ffmpeg commands for working with separate key and fill files:
*) map Y from yuv (alpha only, grayscale) file to new file with a real alpha channel:
ffmpeg -i E:\temp\kf\WIPE02_KEY.mxf -filter_complex format=yuva444p,mergeplanes=0x03010200:yuva444p[4c];[4c]alphaextract -c:v prores_ks -pix_fmt yuva444p10le e:\temp\kf\withalpha.mov
*) Merge key and fill from 2 separate yuv files into one (ffastrans layer compatible avi). This is something we occasionally do at broadcast, as SDI signal doesnt carry alpha, we store alpha in a separate file. Here is how we can work with it:
ffmpeg -i e:\temp\kf\WIPE02_KEY.mxf -i E:\temp\kf\WIPE02_FILL.mxf  -filter_complex format=yuva444p,mergeplanes=0x03010200:yuva444p[4c];[4c]alphaextract[1c];[1][1c]alphamerge[out] -map [out] -c:v rawvideo -pix_fmt rgba e:\temp\kf\merged.avi
Note that instead of -c:v rawvideo you could also do any other codec with alpha, e.g. -c:v prores_ks -pix_fmt yuva444p10l
*) Finally, when we have all components in a single file, use it for overlaying onto some other video (same as layer processor does but compatible to more file formats with alpha):
ffmpeg -y -i e:\5.1.mp4 -i e:\temp\kf\merged.avi -filter_complex [0][1]overlay[v1] -map [v1] -map 0:a -c:a copy -c:v libx264 -preset ultrafast -shortest e:\temp\kf\finaloutput.mp4
Hi authorleon,
In Premiere you must use "None" as video codec and set to 32 bit depth. It should give you a proper rgba file.
authorleon
first of all thank you for the post second of all let me try that and now get back to you and I will respond to emcodem.
Thank you
admin wrote: Mon Jan 09, 2023 12:14 pm Hi authorleon,
authorleon
okay, I finally got it working. There was a setting that was set to 24-bit as opposed to 32-bit.
I have a question. The file sizes are colossal. Is there any alternative?
thanks
authorleon
Wow. Thanks. I will need to go through this in detail!
authorleon
Hello all:
I have a question. The file sizes are colossal. Is there any alternative? Smaller file size?
Thank you
PS: @emcodem, thank you for the info. But that is a little too complex at present.
Yeah sorry, sure you dont want to work with separate files, i just added my ffmpeg commands in order to preserve them next time when i need them :D
The reason why we only support uncompressed avi is that the videolayer processor is an unloved stepchild, it uses the avisynth source plugin "Avisource". But as far as i see, the "eat everything" source plugin ffvideosource also supports alpha channel these days.
So why don't we just try to replace the word "Avisource" by "ffvideosource" directly after the videolayer node?
Here is how i generated a small webm video from a transparent png for testing, you need to test which format + alpha from premiere is supported by ffvideosource (e.g. quicktime animation?).
ffmpeg -loop 1 -i Desktop\transparent.png -r 30  -pix_fmt yuva420p c:\temp\transpavideo.webm
Here the workflow, it reads the .avs script after the videolayer node (%s_source%), replaces "Avisource" against "FFvideosource", writes the result to a file in work_folder and sets %s_source% to the resulting avs script. Tested with above webm transparent source, works for me.
emcodem_videolayer_ffvideosource.json
(4.85 KiB) Downloaded 446 times
Of course we can alternatively take a custom avs processor and recreate what the videolayer proc does. Looking at the source code of the videolayer processor, there is no logic at all, so basically it is just a convenience function for inserting these lines into the avs script (but it uses avisource instead of ffvideosource):
NOT TESTED:
m_clip = ConvertTo8Bit(m_clip)
videolayer = FFVideoSource("C:\Users\emcod\Desktop\transparent.webm").converttorgb32().LanczosResize(m_clip.Width, m_clip.Height).ConvertFPS(m_clip.FrameRate)
audiolayer = BlankClip(m_clip, length = videolayer.FrameCount, color=$000000)
medialayer = AudioDub(videolayer, audiolayer)
m_clip = ConvertToRGB32(m_clip)
m_clip = Layer(m_clip,medialayer, "add", Round(254))
m_clip = ConvertToYUV444(m_clip)
Return m_clip
Edit: if the alpha source is interlaced, use ConvertToRGB32(m_clip, interlaced=true)
