Watch Folder Stops Working
graham728
Post by graham728 »
I have a workflow/watch folder that gets used quite a lot. Other watch folders are working fine.
Occasionally it just stops working. Files dropped into the watch folder will not process - I've tried renaming the files, resetting the workflow, disabling and re-enabling the workflow and nothing.
I've copied pasted all the nodes into a new fresh workflow and still nothing.
The watch folder settings are
Deny Attributes - all selected.
Forget Missing Files - Selected
Check growing files - Once
Limit filesize - none
graham728
Re: Watch Folder Stops Working
Post by graham728 »
Sorted it. For some reason, the files being submitted by a particular user are being flagged as archive in the file properties.This user uses Avid whilst the rest of the team uses Premiere Pro.
