FFastrans_Windows Server
luzimarsorgi
Post by luzimarsorgi »
Hi, FFASTRANS is compatible whit windows server?
Tks.
Re: FFastrans_Windows Server
Yes, 2016 or better. But it will likely also work on 2012....
For webinterface, we use mongodb and they force Server 2016 (~=windows 10) or newer.
The reason for the forcing are as far as i understand mostly the "linked" Windows inbuilt "encryption" libraries for https related stuff and similar, it is the base of all security related matters.
luzimarsorgi
thank you very much.
luzimarsorgi
Sorry, it´s me again. rs. FFastrans can move folders? If yes, how?
@mahirat interesting, how do you do that?
@mahirat everything you write is AI generated and some things you say do not make a lot of sense. Please do not post AI generated text but use a translator if you don't speak english.
