Avid DNxHD: Changes in audio layout are not saved
Locked
bephop
Post by bephop »
big thanks for implementing 24bit audio and the "Audio Layout" option for DNxHD. But the layout option does not work :( You can select "discrete", but the changes will not be saved an take no effect to the encoder. If you reopen the settings dialog the option is set back to "coupled".
Thanks,
bephop
Re: Avid DNxHD: Changes in audio layout are not saved
OK, Thanks for reporting! I'm not able to look at this at the moment as I'm abroad and not back until mid-february.
Hi bephop,
I'm sorry but I completely forgot all about this bug but it's been corrected for the next release.
bephop
Post by bephop »
:) no Problem. Thanks for fixing!
Locked
