Hi all!
I am new to FFAStrans, but have set up a workflow as following:
Watchfolder --> Decoder --> Encoder --> Delivery
It is supposed to be very simple, drop a file in a folder, decode it, encode it and write to another folder.
Whatever I do I get this error when the workflow starts to encode: "No video or audio found in media".
Since the forum doesn`t allow me to attach .txt files I have pasted the log for the workflow in question here: https://hastebin.com/datotohora.tex
Thanks for any help!!
No video or audio found in media (Logs included)
Re: No video or audio found in media (Logs included)
Hi magnuso, thank you for using FFAStrans and welcome to the forum!
Can you please try and skip the decoder and go straight from the monitor to the encoder, and let me know if that helps?
