Hello, Steinar!
Maybe, you are using some packer for exe, or code obfuscator? After last av-bases update, this crazy software kill process and delete file.
Windows Defender alert (def_runner.exe)
- def_runner.exe.png (87.33 KiB) Viewed 10017 times
Re: Windows Defender alert (def_runner.exe)
I'm getting the same alert from McAfee OAS which is preventing me from installing the 0.8.2.2 patch. Is there a place to download older versions before this was implemented?
This is a constant problem with AVs. Can you please try and exclude the FFAStrans files from beeing checked?
