Issue In Folder structure for HLS Output
dinesh24
Post by dinesh24 »
We have created HLS output using below ffmpeg command.
1) 300kbps
-c:v libx264 -s 320x240 -b:v 300k -maxrate 300k -bufsize 400k -pix_fmt yuv420p -refs 1 -profile:v baseline -level 3 -g 36 -sc_threshold 0 -flags -global_header -movflags +faststart -c:a aac -strict experimental -ar 48000 -b:a 64000 -ac 2 -f segment -segment_time 10 -segment_list "D:\HLS Test\Output\%s_original_name%\300.m3u8" -segment_format mpegts "D:\HLS Test\Output\%s_original_name%\300_%05d.ts"
2) 600kbps
-c:v libx264 -s 640x360 -b:v 600k -maxrate 600k -bufsize 800k -pix_fmt yuv420p -refs 1 -profile:v baseline -level 3 -g 36 -sc_threshold 0 -flags -global_header -movflags +faststart -c:a aac -strict experimental -ar 48000 -b:a 64000 -ac 2 -f segment -segment_time 10 -segment_list "D:\HLS Test\Output\%s_original_name%\600.m3u8" -segment_format mpegts "D:\HLS Test\Output\%s_original_name%\600_%05d.ts"
3) 900kbps
-c:v libx264 -s 1280x720 -b:v 900k -maxrate 900k -bufsize 1200k -pix_fmt yuv420p -refs 1 -profile:v baseline -level 3 -g 36 -sc_threshold 0 -flags -global_header -movflags +faststart -c:a aac -strict experimental -ar 48000 -b:a 64000 -ac 2 -f segment -segment_time 10 -segment_list "D:\HLS Test\Output\%s_original_name%\900.m3u8" -segment_format mpegts "D:\HLS Test\Output\%s_original_name%\900_%05d.ts"
Using above HLS package created in single output folder. we want to create HLS package in separate folder. for that we are using command executor with below code even it is create the output in separate folder. please help me to rectified issue. please find attached screen shot for your reference.
Dinesh
folder structurePNG.PNG (50.57 KiB) Viewed 19221 times
dinesh24
Re: Issue In Folder structure for HLS Output
Post by dinesh24 »
:D
dinesh24
Post by dinesh24 »
dinesh24 wrote: Mon Oct 16, 2017 6:57 am Please note below command executor..
%ComSpec% /c "md "%ComSpec% /c "md "D:\New Test\300" "D:\New Test\600" "D:\New Test\900""""
"D:\HLS Test\Output\%s_original_name%\300\300_%05d.ts"
"D:\HLS Test\Output\%s_original_name%\600\600_%05d.ts"
"D:\HLS Test\Output\%s_original_name%\900\900_%05d.ts"
gives you a directory for each original Filename with the three bandwith-directories.
is wrong imho.
%ComSpec% /c "md "D:\New Test\300" | md "D:\New Test\600" | md "D:\New Test\900""
But you don´t need it, the command-executor nodes above do make the directories.
tom
dinesh24
Post by dinesh24 »
Thanks for update....
as u suggested I have tried below command in ffmpeg preset. separate bitrate directory is not created.
Even i am trying with command executor node separate bitrate directory is not created.
%ComSpec% /c "md "D:\HLS Test\Output\300" | md "D:\New Test\600" | md "D:\HLS Test\Output\900""
Please help me to rectified issue.
Dinesh
Sorry - it is "mkdir" , not "md".
tom
