populate variables do not work
Hi folks,
wondering if anybody else got this problems.
I´m on FFAStrans 0.9.0, processor.exe 0.9.0.17.
I never used the "populate Variables (PV)"-Node so far. Therefore I cannot tell, if it worked in former versions.
I tried to set a user variable hitting the triangle left of "none".
A Dialogue opens (select Variable).
right-click "new" -> set "Variable" and name it to "thommes_Test_Var".
Set a description.
BUT I cannot set it to "variable". it will stay as "static" after re-opening the dialogue. I further cannot call the help-menu or do anything else.
I can see the variable in the Variable-lists in the other nodes, but how do I set them to variable in the PV-Node?
thanks in advance,
-Thomas
Re: populate variables do not work
Hi Thomas,
That sound strange. I'm noe able to reproduce the issue on the version you're using and I've never heard of that issue before either. That does not mean it's not a bug.
Statics are forced to capital letters so your variable should read "THOMMES_TEST_VAR" if it was a static. Have you tried creating new or other variables?
