Hi steinar,
Thanks for your hard work and keep updating the software!
I am having issue on loudness analyses on0.9.3. It simply just not able to generate loudness value. I tried to export the loudness variable to a txt file. The txt containing [] only. I ran the same workflow on 0.9.2.1 and it works fine, with value inside the bracket [].
Attached my test workflow for your reference.
thanks,
Panda
Loadness analyses on 0.9.3
- variableTEST.7z
- (1.44 KiB) Downloaded 1013 times
Re: Loadness analyses on 0.9.3
You are right! It's broken. Expect a patch very soon. Thanks for the report!
Edit: Patch is ready now for download.
Hi steinar,
thanks for quick fix.
Unfortunately, there are discrepancy between the values generated by 0.9.3.1 and 0.9.2.1. The values generated by 0.9.2.1 looks more reasonable to me.
Attached is the values read from 2 version using the same source file.
thanks,
Panda
thanks,
Panda
- test.7z
- (232 Bytes) Downloaded 905 times
Are you sure your 0.9.3 settings is not set to "All combined"? Cause that's what you get if it is; the same result on all channels. I just tried both versions and both show the same result on the same file with the same settings.
Ah...let me try. Hopefully it's just wrong setting from my side!
Thank you, Steinar!
Thank you, Steinar!
Is the loudness analyser broken again? I'm on version 0.9.3.55 and still getting an empty string when using the node
Hm, that's strange. The latest "processors.exe" is 0.9.3.44. Can you please confim you have the updated version? It's seem to be working as it should in my tests.
Ah, yes! It's working now, I was on 0.9.3.43. Thanks, Steinar!
Great, I was a bit worried my sloppiness reached a new level...
