24fps -> 25fps and create more channels
gunnar
Post by gunnar »
I have Apple prores (.mov file) that is in 24fps and in 5.1 surround with 6 channels mapped as L, R, C, LFE, Ls, Rs.
I need to deliver this file in 25fps MXF XDCAM HD format and with stereo on track 7 and 8. At the moment this stereo does not exist since the file is in 5.1 so i was wondering can i let FFAStrans create stereo on channel 7 and 8 from the 5.1 mix while exporting?
And i need the framerate to be 25fps, should i use some frame blending mode or is some feature there that actually speed the file up from 24fps to 25fps and correct the pitch back?
Re: 24fps -> 25fps and create more channels
Hi gunnar, thank you for using FFAStrans and welcome to the forum! :-)
Yes, you can do this with FFAStrans. Please import the attached workflow. This will create XDCAM-HD file with the original first 6 channels and the mixdown on 7+8. The encoder itself will take care of the 24->25 fps conversion. The workflow has not monitor or delivery node so you need to connect those yourself.
Mixdown and merge.xml
(10.2 KiB) Downloaded 739 times
gunnar
Post by gunnar »
Thank you so much!
Sorry for all the questions but i am new to the software and still learning.
What would i add to this if i want the file to be -23 lufs?
I saw there is some loudness node there but i was not quite sure on how to set it to be -23 lufs :)
