variable urlencode
variable urlencode
Post by taner »
Hello Steinar,
Concerning variable: urlencode
Sorry, I'm not sure about the correct terminology, so I try to explain it with an example:
May it possible to have the possibility that a special character like ( can be encoded to %28?
At the moment this special character, among others, stays the same after being processed.
Taner
Re: variable urlencode
Hey Taner, what are you after, is it filename normalizing, so removing special chars from filenames?
Cheers,
Post by taner »
Hello emcodem,
Thanks for insisting.
@Steinar: please forget the request.
The problem I had with the generated url was because the original filename has umlauts.
Our system (streaming-server) can't handle umlauts.
Sorry for the inconvenience.
Taner
