Missing .dll file
st-tb
Missing .dll file
Post by st-tb »
Hello everyone,
can you please help me with following?
When the workflow enters A/V Media node, the following error pops up:
which basically says that the ffprobe.exe cant be executed because the computer is missing api-ms-win-crt-runtime-1-1-0.dll and that I should re-install the program.
Any help please?
Thanks a lot!
Re: Missing .dll file
Hi st-tb,
Have this previously worked? In other words, has anything changed in your setup?
st-tb
Post by st-tb »
No, this is completely new PC and first time usage :)
What Windows version is it?
st-tb
Post by st-tb »
Thanks a lot for your help :)
Hello st-tb,
Do your windows 7 is up to date? It looks like a missing windows update or a missing vc_redist .
st-tb
Post by st-tb »
Actually, it´s very much not up to date, as it´s a clean installation of an old Windows 7 licence with SP1. We dont really have a way of updating it, as it´s on a network that is completely cut off the grid and offline.
Do you think it´s an old Windows issue?
Yep, this kind of message really looks like a missing update and if you tell me your workstation isn't up to date it's really likely.
You can try to download vc_redist here :
https://support.microsoft.com/en-us/hel ... -downloads
Tell us if it's ok ;)
st-tb
Post by st-tb »
hot damn, that did the trick!
thank you SO MUCH!!!
You're welcome guy !!
