Merge more files in a single files
ppmazm
Post by ppmazm »
Merge more files in a single files....
Can I merge more files in a single files with the required sequence in any required format ?
Re: Merge more files in a single files
Hey ppmazm,
There are mutliple ways how to do this but currently no really easy one.
Are you able to generate a text file containing all your filenames that you want to merge like this in your future production workflow?
ffconcat version 1.0
file '\\server\share\file1.mp4'
file '\\server\share\file2.mp4'
FOIS
merge an XDCAM HD OP1A HD video file into mxf
Post by FOIS »
I would like to be able to recover a Workflow in .xml.
The would like to be able to merge an XDCAM HD OP1A HD video file into mxf and 4 wave audio files to XDCAM HD OP1A.
The Workflow should only run if the files are present.
thanks in advance
Vincent ƒœîÒ
Hi @FOIS
What you want to do looks very different from this topic, maybe next time open your own, new topic?
Is this what you want to do?
viewtopic.php?f=5&t=947&p=4261&hilit=m2v#p4261
Hello Fois,
You can add a "hold" node just behind your monitor node to wait the audio file. Check "wait for file(s)" inside Hold node and enter the full path of your audio file (can be the same folder than video folder, name your audio file like video file and use the %s_original_name% variable). The merge will start only when the audio file will be in folder.
Hope it helps.
benjamin
