:!: 0.9.4.0 FFAStrans crashed, not importing new files :!:
veks
Post by veks »
:!: After FFAStrans.exe crashed it won't get new files to the workflow, even when I try to manually submit them!
Any way to get it up and running?
I've tried:
1. restarting service
2. restarting server
3. deleting workflow and importing them again
4. creating a new workflow
None works.
veks
Re: :!: 0.9.4.0 FFAStrans crashed, not importing new files :!:
Post by veks »
@admin
@emcodem
guys, sorry for bumping, but I need an solution fast.
Should I reinstall, or is there a better way?
Thanks a lot!
veks
Post by veks »
Copying latest update files (0.9.4.1) (folder, EXEs) over the FFAStrans folder worked out!
veks
Post by veks »
Sorry, it didn't worked out.
What to do?
EDIT: I can see it in Web GUI that it's queued, but FFAStrans doesn't get it.
veks
Post by veks »
Even when I reinstalled service, put freshly downloaded FFAStrans, removed the old one etc.
Imported old workflows and it still won't work...
Any ideas?
Hi veks,
Sorry you're having trouble. Is the exe_manager running?
