processors:monitor_gopro
GoPro Monitor
Purpose
Watch folder for GoPro files structure.
Original Manual
This monitor looks for GoPro material and concatenates spanned clips.
Set folder that will be monitored. May be local or UNC. Supports variables and drag'n drop. The monitor looks for GoPro file structure so the setting should point to the root folder.
Create folder
If this is checked, FFAStrans will automatically create, if it does not exist, the folder specified under«Folder».
Check for growing files
This option will make FFAStrans wait to see if incoming files are still growing. The speed of the cycle is defined by the sleep timer setting in the workflow properties.
Forget missing files
Rebuild history
Clear history
2019/12/09 16:19
processors/monitor_gopro.txt · Last modified: by ffastra
