Table of Contents
Panasonic P2 Monitor
Purpose
Watch folder for Canon P2 files structure.
Original Manual
Folder
Set folder that will be monitored. May be local or UNC. Supports variables and drag'n drop. The monitor looks for a Panasonic P2 file structure so the setting should point to the root folder of PP2. The monitor also supports clips spanned over several disk and will automatically search for these in the same monitors folder. If they cannot be located it will try to searching local removable drives.
The latter excludes farming unless the drives has been shared and mapped on all members of the transcoding farm.
Create folder
Cobine all clips into one
Combines all available clips into one continuous clip.
Forget missing files
Mux all clips essence to
Sets the media wrapper for the output files.
Read clip XML to variable
Select a variable to store the P2 sidecar XML information as is.
Rebuild cache
Clear cache
