Autolt v3 stop Windows 10 from shutting down.
authorleon
Post by authorleon »
Fantastic piece of software.
I have been testing it out and it appears I have found a bug.
When shutting down windows I get this error box.
https://ibb.co/Q9qHR4k
Re: Autolt v3 stop Windows 10 from shutting down.
Hi authorleon,
running as a background service or as application?
authorleon
Hey emcodem,
Running as an application.
Ok, so the error itself can be ignored; we don't care if the application closes correctly or not when shutting down.
As we come up with a new release very soon and the error seems to be kind of related to your environment, i suggest a workaround:
disable_error_reporting.reg.txt
(153 Bytes) Downloaded 1070 times
You know .reg files? ..after downloading, rename this file from .txt to .reg and just double click it; it OK then.
I hope this will surpress the corresponding error message and you can shut down without this annoying error message.
authorleon
Hello emcodem,
I have applied the registry file. And as you can you downloaded three times just to make sure. Unfortunately continues to happen.
however this time the behaviourism to be different:
Whereas before, windows would not shutdown. This time windows is shutting down the error message is still showing.
Thank you
authorleon
sorry to be the bringer of bad news.
We have the same issue.
Thank
uhm, we will talk internally about it, uno momento....
authorleon
emcodem wrote: Thu Jan 28, 2021 4:13 pm uhm, we will talk internally about it, uno momento....
Okay, Thanks
OK, we need a little help from you and find out if the "name of the executeable" that is preventing the shutdown is "exe_manager.exe" or different.
Are you able to check the windows application log, as described here?
(Method 3: Using Event Viewer to find the process responsible for the warning message):
https://appuals.com/fix-this-app-is-pre ... -shutdown/
Hopefully you are able to find out the real name of the .exe that is preventing the shutdown and tell us here...
authorleon
Thank you for the link. I have tried what you suggested. This is the message I have.
I also added the registry edit which is stated in the article. And I am testing it out.
I have this message:
Application pop-up: AutoIt v3: exe_manager.exe - Application Error : The instruction at 0x000001C2D2B1002F referenced memory at 0x000001C2D2B1002F. The memory could not be written.
Click on OK to terminate the program
