processors:monitor_ftp
Table of Contents
FTP Monitor
Purpose
This processor is used at the start of a workflow to watch for new files on a FTP.
Original Manual
Server
Port
User name/Password
Path
Accept/Deny files
Forget missing files
Limit file size
Recurse
Check for growing files
Rebuild cache
Clear cache
2019/12/09 16:19
processors/monitor_ftp.1581278020.txt.gz · Last modified: (external edit)
