Table of Contents
FTP Monitor
Purpose
This processor is used at the start of a workflow to watch for new files on a FTP.
Original Manual
Server
Port
User name/Password
Path
Accept/Deny files
Forget missing files
Limit file size
Recurse
Check for growing files
Rebuild cache
Clear cache
